Hey guys, I recently bought this GTR and I'm not in a rush to sell it, I love it. I'm just putting it up for sale merely as an expression of interest, an exercise out of boredom if you will. If it sells, I'll move on, if not I'm completely happy to keep it :)
The engine was built by Gavin Wood on the Gold Coast, the mods are as follows:
CP Pistons
Eagle Rods
Tomei 270 cams
Springs/Retainers
N1 turbos with HKS actuators
Full custom tucked 3.5" exhaust and high flow cat made by Fabulous Fabrications (beautiful work) along with custom Hot/Cold cooler pipe.
Intercooler
Haltec Platinum Pro ECU
Bilstein/Eibach strut/spring combo
Cusco Swaybars
Cusco 1.5w rear diff, fully rebuilt and new diff bushing installed with newer (and slightly larger/stronger) R33 half shafts
Ikeya Formula front and rear upper control arms.
HICAS delete.
Desmond Regamasters in 17x10 + 20 wrapped in near new Federal 595 RSR's
The car made 385hp at all four on 18 psi and at a very rich tune of 11:1 up top. If I keep it, it'll be getting a retune shortly for more boost and a little less fuel, but it's quick as it is.
Aircon is cold, chassis rails are straight, no rust, this is a clean GTR :)
2 minor issues, the passenger side dash vent is missing (previous owner broke it trying to install a cup holder) and it needs new coil pack connectors and possibly coil packs. The coil issue will be taken care of prior to sale and I can chuck a vent in it, I just haven't found one for sale yet.
$21,000 ono
Will entertain the thought of trades, just depends on what I'm being offered but send your offers through anyway, it can't hurt!
0401029817
https://www.sau.com.au/forums/topic/437696-r32-gtr-forged-motor-mods/
Since listing for sale the car has had
New coils (old coils were fine, misfire was being caused by a boost leak thanks for a faulty coupler)
Service in the last 100km
Brake rotors machined and pads linished, brand new pads
Replaced coupler to get rid of boost leak
The car is ready for its new home
It's an 89 Grant, yes I have a dyno graph floating around somewhere.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
