  • 3 weeks later...
Ok guys the dates of the next cruise is April 27th 2014 same meet at 8am
Hope to meet more of you there.
Please PM me or post for any questions.
Also I have created a FB GTR Cruising SA Group for those of you are interested please PM me
Mike
any pics from the last cruise boys.....heard there were a couple or 3 nice GTR's there!
If your talking about R33s then yes there was. There were nice R34s as well. Will keep April 27th free also Mike.
  • 4 weeks later...
Hope to see more GTRs out this cruise. Please keep the 27th of April free for the next cruise. Hope to have a pro photographer on this cruise too
don't forget to join the FB group GTR Cruising SA
mike
  • 5 weeks later...
  • 3 months later...
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
