Guys I have tried searching but no real help.
I am trying to sort out a issue on my bro in laws r32, it won't rev past 3000rpm it coughs and splutters when it's warm. It has a z32, nistune, walbro pump, kkr 430 and a 14psi external gate and split fire coilpacka
There is no boost leak that I can find, spark plugs are gapped at .8 cleaned the afm, I don't have another afm so I can't try that. But it's really annoying me.
Also tends to stall when you come off the gas in neutral.
I am thinking of afm but don't have a z32 to try.
Any thoughts guys
https://www.sau.com.au/forums/topic/437980-r32-issues/
Idle control valve??? It idles at 2200rpm when it is plugged in and been told by previous owner it doesn't need to run it supposedly???? (Not sure if that's right though)
It's definately not ic piping or boost leak from silicone hoses that I can see at least.
I am starting to think tps or maybe idle control valve but that doesn't sort out the 3000rpm spluttering
I think he is gonna have to take it to a tuner.
https://www.sau.com.au/forums/topic/437980-r32-issues/#findComment-7177475
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
