For sale is my 1992 Nissan Skyline R32 GTR.
Perfected with a Mines kit and tasteful mods a great example of a 22 year old Godzilla GTR, has a few paint chips on the front lip and a few little scuff marks as you can see in the pictures, has been my weekend car and a pleasure to drive, does not have any oil leaks and has been well maintained by myself and Gavin wood autotech, unfortunately I’m moving to a smaller place with only a single car garage so having 2 cars has become a bit of an inconvenience, as it isn’t driven much these days it’s time to sell it, more details below and if you’re interested in inspecting it please message me or call my mobile on 0414197167, thanks
  • Tein coilovers
  • Jun oil pump
  • Mines Kit – mines ECU, air flow meters, 320km speedo cluster and exhaust
  • Second Australian owner (privately imported in 2008)
  • Engine rebuilt in Japan before importing
  • Freezing cold air con
  • Reconditioned turbos inspected and installed by Gavin wood late last year with braided lines
  • Platinum spark plugs (5000kms ago)
  • 200k service completed (10,000kms ago) included timing belt and water pump
  • Turbo, rocker cover and plenum gaskets replaced less than a year ago
  • 42mm Aluminium radiator
  • Every heater and water hose replaced with autobahn88 silicon hose kit
  • Silicone engine breather hoses
  • Greddy turbo timer
  • Greddy profec B boost controller
  • HKS SSQV blow off value
  • Slotted front and rear brake rotors
  • RDA sports brake pads
  • Mongoose keyless entry\alarm\immobiliser
  • Ganador mirrors
  • Lightweight Enkei rims
  • Kenwood 10” sub and amp
  • Colour Arctic white
  • Long rego (ends in October )
Video - http://youtu.be/TiWeqAL_zVo
Edited by philpug
https://www.sau.com.au/forums/topic/438330-1992-nissan-skyline-r32-gtr/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
