A set of freshly powder coated semi gloss black Rays Engineering Nismo LMGT4's in 18 x 9.5 +12 offset . Comes with a set of 70% Yokohama Advan Neova AD07's in 265.
Will put up pics tomorrow.
$3500
Final price of $3200 , before these will no longer be for sale.
I can't believe someone hasn't jumped on these at this price .
Still for sale ..$3000 with no tyres.
This is a farking bargain..why has no one jumped on these? :huh:
Is everyone more interested in putting shit phillipino rota's on their gtr's these days :down:
  • Like 1
china are a 3rd of the price for new.
in saying thay, id love to buy these, but like most, no money.
glws.
Bullshit have a look at what they are selling for in Japan these days
Huh?
Sell it to Japan then.
Our market is not Japans market...
  • Like 2
they need to be 10.5 wide... i got alot of enquiries on my wheels when my car was for sale, ppl offering 2-3k plus replacement wheels etc..
offered $2.5K, rejected as lowballing?
It is low balling as far as I'm concerned..go and find a set in this size and condition for the amount you expect to pay..Good luck your going to need it. ;)
glws.
Anyone who puts chinese shit (or phillo shit) on gtr's needs shooting..If you want to be that f**king cheap go buy a hyundai
Edited by ezy_09s
  • Like 1
There are few sets available on our market, have a look on Japan yahoo auctions then factor in the usual expenses to get them here and taxes. Wait till the $1000 tax free limit is removed on imported goods in a year or two.
They don't need to be 10.5 wide to be worth 3k + especially not if they are going on a R32, look at the set PAV34 sold recently he was asking 4k and I would say got very close to it.
A 9.5 +12 is only going to sit 10mm further inside the wheel arch than a 10.5 +15. The z-tune didn't have 10.5....
Owgasm is right though u just need to wait for the right buyer, around tax return time or Christmas is usually the best
Rejected $2800 GLWS
You expected me to send them to victoria for $2800 including shipping. ha ha
You might find a shit condition set for what you want ..if your lucky
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
