Aftermarket parts galore
Tein super street Coilovers with edfc (electronic dampner control) suit r33 r34 Gtr and r34 gtt like new $900
Splitfire coilpacks to suit rb20 rb26 and rb25 s1 great condition $340
Apexi avcr black edition comes with manuals etc complete $440
Xforce stainless dump pipes for rb26 with O2 sensors $200
Greddy t517z turbos suit rb26 one turbo has been fully rebuilt other one is still in mint condition comes with braided lines and full gasket kit $1500
Gtr 100mm intercooler no brand $200
N1 turbo steel wheel rebuild kit for standard r32 r33 Gtr turbos $200
Rb26 stainless front pipe $150
Greddy turbo timer $30
Pivot speed cut and meter $50
Splitfire gauges $30
Auto meter gauge set of 3 $70 for the set
Hicas lock bar to suit r33 r34 $40
Apexi boost gauge $40
Drift boost gauge $30
Yellow earthing kit $20
Nismo gear knob not the best of condition $20
Rb26 catch can set up $100
Rb26 hks fuel rail missing hks badge $50
R33 Gtr genuine strut brace front and rear $70 each
Nardi boss kit $50
R32 Gtr fuel pump cradle with walbro fuel pump $70
Short shifter removed from r33 Gtr $50
Gold Coast
0487924497
post-50709-0-57927300-1392265851_thumb.jpgpost-50709-0-76542200-1392265892_thumb.jpgpost-50709-0-33142700-1392265925_thumb.jpgpost-50709-0-29767700-1392265950_thumb.jpgpost-50709-0-43017800-1392265993_thumb.jpgpost-50709-0-55026400-1392266026_thumb.jpgpost-50709-0-00124900-1392266054_thumb.jpgpost-50709-0-50486800-1392266120_thumb.jpgpost-50709-0-27789100-1392266155_thumb.jpgpost-50709-0-33388600-1392266178_thumb.jpgpost-50709-0-58324800-1392266199_thumb.jpgpost-50709-0-47900200-1392266238_thumb.jpgpost-50709-0-85122900-1392266290_thumb.jpgpost-50709-0-92597100-1392266500_thumb.jpgpost-50709-0-36197100-1392266636_thumb.jpg
Edited by toy515
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
