Hi All,
I have for sale, a brand new Cusco D1 Chromoly (blue) 5 point roll cage to suit a 180SX. As per Cusco Japan site, the 180SX model (part no: 221 261 DS) is to suit both sunroof and non-sunroof. The hoop sits further back towards the rear roof of the car up along the roof lining.
Although people say that the Cusco S13 non-sunroof also fit 180SX non-sunroof, this is partially correct/incorrect (however you like to look at it). I've had the S13 non-sunroof cage in the 180SX before and I can tell you that the hoop sits past the driver/passenger seats towards the front of the car and hits your head which to me is a big no no! According to Cusco, the S13 cage has two models, one for sunroof and one for non-sunroof.
Please confirm for yourself, but I believe that the 180SX model will fit in the S13, although the hoop will sit further back like how it does on the 180SX. This is better in my eyes as it won't crack your head open when it happens to knock into the hoop.
Anyhoo, the cage I'm selling is still brand new, wrapped in original plastic packaging, comes with all the plates, nuts, bolts, washers, and paint protection for where the holes are drilled. Everything you'd get brand new!!!
Also, I purchased black Cusco roll cage padding and acetape to cover the full cage. This is also brand new and untouched in the package. This will be included in the sale.
Unfortunately due to the size of item, this sale will be pick up only (Burwood East VIC). Unless you arrange a courier yourself.
I'm after $900 ono for the lot.
Preferred contacted via sms on zero four two one 1 2 1 eight one right.
*Pics will follow tonight*
Cheers,
Andy
Edited by AnDyStYLe
  • 1 month later...
Bump!
I also noticed that I have another spare set of Cusco supplied bolts, nuts and washers to bolt up the cage to the backing plates. These are brand new.
Shoot me through a text if you're keen. Good for those that got a second hand cage that more than likely didn't get the bolts etc. with it.
Cheers,
Andy
  • 3 weeks later...
  • 3 weeks later...
Hey Mate,
Did you get my PM? An error message came up after I sent it so I'm not sure if it got through.
Also does that cryptic phone number have enough digits? I count 9?
Dale
^ It's looking like it's sold at this stage, just waiting on confirmation regarding the courier that the buyer is organising.
If that falls through, then I'll give you a shout.
Cheers,
Andy
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
