Hi , I'm looking for some help/advice.
I finally got around to putting coilovers in my bnr34 and was wondering what ride height others are running?
I have them at fairly even heights front and rear atm.
Any help would be awesome! Btw I have 19 rims.
https://www.sau.com.au/forums/topic/439337-r34-gtr-ride-height-help/
Rims make no difference, but rolling diameter must be the same within a few percent to be legal and to make sure your speedo is accurate.
IIRC all GTRs are the same with respect to hights (but i'm not 100% sure). So you want lowest of 350mm front 340mm rear (wheel centerline to guard). If you want higher, say if you have clearance problems under the car, then just make sure the front measurement is 10mm higher than the rear.
If you're going to track it, get it corner weighted after you've settled on the height you'll run.
You want the least amount of neg camber on the rear that works. So the usual range is about -0.75° to -1.0°. That tends to give the sort of compromise between straightline grip, tyre wear on the inside edge and cornering grip for a street car. A stiffly sprung track car on sticky tyres might want to run a lot more camber.
The same rules apply at the front but you can run a little more camber. Up to -1.5° is the normal range. But again, your mileage may vary, depending on how the car is used, the tyres, etc.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
