Hey guys,
I'm after some expert help!
I have recently finished my conversion of a
freshly rebuilt RB25 NEO into my s13 and it won't start! It has a base tune in it and it's ready to go. It just cranks and sputters a little bit on first start for maybe 1 second and then just keeps cranking.
I had it started and running once after a lot of cranking under full throttle and advancing the CAS And it idled and ran revved perfectly and seemed to have no issues once started. It just hates cold starting it seems.
I had the wiring loom custom made by
Wiring specialties in USA
And have checked the following;
Fuel pump primes
Fuel lines correctly routed
Fuel being delivered to rail
Cam timing perfect
Injectors and coils/spark plugs work when CAS spun by hand
CAS rotates with exhaust cam
I'm a bit lost as to where to start checking next
Any help will be greatly appreciated!
https://www.sau.com.au/forums/topic/439451-no-start-rb25-neo-in-s13/
Guest
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
