Hi guys,
These parts are off my GTR, all parts have done about 3000km as the car was hardly driven:
Vipec V44 ECU - $1000
Sard 700cc injectors - $500
HKS dump pipes - $350
HKS metal gaskets (exhaust manifold, turbo intake and turbo outlet) - $100
Crank angle sensor - $150
I am based in Sydney and can post interstate :)
Forgot to mention that the vipec has a tune on it by ESP Racing in the ACT, it was running GTRS's with 700cc injectors and made 390kw @ 19psi
Man look? I haven't heard that expression before haha
Really? Well there you go lol
Ubran Dictionary states :
man look
when men (or someone else) look for something but can not find it because they do not look properly. Often whatever they are looking for is right in front of them.
you can't find it because you did a man look
That is gold. I'll add that to my vocabulary going forward.
That deserves a discount on the vipec!
Ive already got a Vipec, Im trying to convince my mate to upgrade from his prehistoric Power FC lol
Yeah I've had 2 power fc's back in the day and a lot has changed since then, even carbies were good back in the day as well
Gotta luv the glitch u get every 15min
Hi guys,
I had a buyer for the vipec do some investigation which we can all benefit from...this ecu suits all skylines from r31 thru to r34 across rb25, rb26, Gtst, gtt and GTR. However, it does not suit the r34GTR as the wiring for the CAS is apparently different.
I can also say that this is better than a v44 (i.e. 4 injector drives and 4 ignition drives) as it has a v88 top board which includes knock protection + it has 6 injector drives and 6 ignition drives. This again is thanks to another sau member who is a tuner :)
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
