Rb26 aftermarket and standard engine parts!!!
R34 Gtr cam and timing cover $370
Arp head studs rb26 $170
Garrett 2860-5 turbos mint $1400
Greddy t517z turbos great condition one turbo rebuilt $1250
Tomei sump baffle $180
Nismo fuel reg $100
Denso 800cc injectors rb26 $400
Splitfire coilpacks $340
Manley rods h beam used rb26 $450
Mahle forged pistons 86.5 rb26 $450
Rb26 block 86.5mm bore mint $280
R32 Gtr crank $150
Rb26 sump with diff $150
R34 Gtr coilpack cover $110
Rb20 rb26 engine mounts like new $100
R33 Gtr alternator 90amp $70
Rb26 bottom baffle plates $20
Rb26 cas $70
Rb26 r32 Gtr balancer $40
Engine brackets $40
Rb26 standard rods $40
Many other parts available
Gold Coast
0487924497
What are your best price for the pair of these? These are direct replacements correct for the RB26 - running N1 turbines... please do confirm with me and let me know.
Thank you!
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
