Hi guys,
Have a small problem with starting up after leaving the car for few hours or when cold.
just started to happen recently.
when I go to start up car when its cold it will sometimes just idle and usually does hold idle ok but sounds like a wrx till it hits around 60/70 temp on my power fc then it will smoothen out and clear up and runs fine.
today it started up fine went around then done it on cold like on 5 cylinders it sounded it was running on and then a minute later or so cleared up and back perfect again and once on normal running temp never has a problem at all can start 100 times and will be fine.
ive got new coil packs/spark plugs/fuel filter
thought maybe blocked injector
havent cleaned the aac valve yet and probably try and clean the afm again after a few month but doubt the afm would do that.
Only does it either first starting up and sometimes in between low and high temp,just before it hits the normal temp and then it will never do it again.
maybe water temp sensor/ecu
any help would be great as kinda stuck for now and hate when it does it until warms up.
https://www.sau.com.au/forums/topic/440242-r33-rough-starting-up/
Look at the cold start valve, might be causing an issue.
Was the idle self learn done properly on the power fc? What does your sensor/sw page in 'ETC' show? If the PFC HC shows temperature normal then it isnt the water temp sensor. Could try cleaning the aac but if it idles ok after warming up im not to sure it will be that.
What does your timing do on cold start and does it smell rich or not really?
Yea it does smell like fuel bad but only when its running like unpluging 2 coilpacks but sounds dufferent to een unplugging a coilgot it dyno tuned at trent done for me and everything perfect and all but had a little hesitation to drive when cold ..so took it back to give it a bit more fuel on cold start and started happening next day.
Fuel was fine and spark was all good.
I guess I can rule out afm,fuel pump and injectors as I no if it was afm or fuel pump it would just either not start or just die which never happens.
Yea it does smell like fuel bad but only when its running like unplugging 2 coil packs but sounds different to unplugging coil packs.
Got it dyno tuned by trent for me and everything perfect and all but had a little hesitation when cold driving it so took it back to give it a bit more fuel for cold start and driving and this started to happen the following day.
fuel was fine and spark all good.
I guess I can rule out afm,fuel pump and injectors as I think if it was afm or fuel pump it would just either die or not start which has never happened.
sorry about the spelling on the before msg as was using mobile phone.
Get some figures off your PFC for us to look at. Give us a rough indication of what your timing is doing (it should fluctuate a couple of degrees, but the average timing or what it sits on the most while its doing it), What injectors and what injector Duty Cycle? What does your sensor/sw page on the hand controller say?
Is the base timing set up right?
I had the exact same issue you are describing, but now #6 cylinder doesn't work at all. It was intermittent until the car warmed up last week. I suspect dead injectors in mine.
http://www.skylinesaustralia.com/forums/topic/439938-car-firing-on-4-5-cylinders-for-a-few-min-until-it-warms-up-and-smell-of-fuel-in-engine-oil/
Might give you some idea.
Thanks for that.
My problem has gotten worse now.
so as i started the car cold and it started to run rough/wrx note for a few seconds and misfire abit as I went for a short drive warmed it up and then pushed a bit of throttle and all good until I came to a stop and the idle started hunting between 800rpm- 1300rmp so decided to drive to go home and would not go past 2500rm and would hesitate and the exhaust note was brrrrrrrrr brrrrrrr and just wouldn't go past 2500rmp.
Got home and turned it off and checked for any leaks and nothing.
so started it again and just hunting betwwen that rpm range I said before.
I did unplug my afm while on idle and turned off but took awhile to turn off like 5 seconds.
thinking it might be my z32 afm.
would a afm do that if it was faulty those symtoms? as I got it with the car this z32 afm but don't wanna buy new one and it isn't the problem.
Edited by RamR33
  • Like 1
Ah sorry I meant from the monitor screen. What the injectors and timing etc are doing real time
Looks like your tps is set wrong though. Should be 0.45v on closed throttle
If the car is running there your o2 sensor looks not quite right to me either
Set the tps and see what happens. I dont think It will go into the proper idle map if the tps is set to high (which yours is)
Well I've replaced the o2 sensor with a working one so then I took the photos.
What if my tps is damaged could it be on that reading it's showing?
I've changed fuel filter,fuel lines,new afm,spark plugs..
I'm running stock bov which I've got one spare to replace just for piece of Mind u guess.
I'll try get the monitor reading pictures for better understanding.
I'm running stock bov which I've got one spare to replace just for piece of mind.
I'll try get the monitor reading pictures for better understanding on cold when it's running bad
adjust the TPS before assuming it is wrecked. Not a hard job with the Hand Controller, even easier with 2 people.
With the key on (car not started) Just loosen the 2 bolts slightly, rotate the TPS one way and see if the reading goes down or up. You want to get it to 0.44v-0.50v I think is the spec. Its a bit tricky doing it by yourself but shouldnt take more then 5 mins. I think this might fix your problem a little bit if not completely.
Is the shot of the Sensor/Sw screen with the car idling?
Edited by 89CAL
Car has gotten worse as wont go past 3000rpm now but gets a little bit of boost at around 5/6 psi so might no be a vacuum leak.
Things I have changed and checked to be ok.
AFM NEW but unsure still could be the plug
SPARK PLUGS BCPR7ES .8
FUEL FILTER AND FUEL LINES
INTAKE GONE BACK TO STANDARD
BOV CHANGED WITH WORKING ONE
RE-DONE ALL VACUUM LINES AGAIN
TPS WORKING
COOLANT TEMP SENSOR WORKING
COIL PACKS SPLITFIRE WITH NEW COIL PACK LOOM
Aac VALVE CLEANED
Only things left are fuel pump ,injectors,ignitor box and crank angle sensor.
im thinking fuel pump but still leaning towards the AFM.
Mine did a similar thing. Was fine, voltage was right. Then one day it started playing up. Voltage was still ok but for some reason just wasnt happy. Played around with tps and eventually it came good again. Not sure what happened
Played around but did nothing to be honest and was tuned that way.
Just got worse so taking it in to get it diagnosed tommorow.
Even changed to a brand new fuel pump and AFM.
Will report back here to let u know as I'm just curious and done everything I can do for now.
One thing I did notice last time I tested it was driving it really slow through the Rev range with little acceleration it would get up to 4000rpm but if Im normal driving it struggles to get past 2500rpm 3000rpm and like hits a wall but does make boost like around 5/6 psi depending on how much accelerator I use.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
