Never though I'd do this, but since the Birth of my my son, rarely get a chance to enjoy this car any more, so I've decided to move it on.
Always garaged and car covered - Has 160k on the clock, still running orginal engine.
Extreamly clean, no rust, straight body, no accidents, orginal panels.
only 2,000 ks done since all work was completed.
Standard engine internally.
308 kws at 16psi
Garrett BB 2860-5 turbos with split dump pipes
HKS hard pipes
apexi power intakes
Genuine Nismo intercooler
Genuine Koyo radiator
Carbon fibre air diversion plate
800CC injectors, big intank fuel pump, fuel rail and adjustable reg
microtech mtx-8 computer with MAP sensor (no more AFMs)
HKS EVC-R boost controller
oddessy battery in boot
Custom catch can with braided lines and fittings
HKS coilovers
Power spirit rear camber arms
Nismo strut brace
Veilside andrews 18x9 +20 with new federal 595s
ADR approved braided brake lines
New DBA slotted rotors all round with RG low dust brake pads
Carbon fibre JUN style front splitter
Carbon fibre weather shields
Carbon fibre ganador mirrors (genuine)
Carbon fibre N1 rear lip underspoiler
Genuine Nardi suede deep corn steering wheel (might come with momo wheel instead if I can't bear to part with it)
Titanium shift knob
Nismo gauge cluster
Clarion flip screen DVD player with bluetooth etc
JDM32 number plates
All servicing up to date - timing belt, water pump, new clutch booster, new ABS module etc etc
Have massive file full of receipts etc for everything done over it's life in Australia, including orginal import paperwork. Also have pictures and video of the work being completed, including dyno runs.
Also comes with stock everything- wheels, steering wheel, front splitter, intercooler and piping, radiator, mirrors, turbos, air box, computer etc - everything to return it back to factory spec.
If your keen drop me a line 0412 720 901
$27,500 ono as is. Available to view in Taylors Hill.
Also have a matching black GTI-R that can be negotiated into a package deal for someone wanting the family of Godzillas :D
Cheers
Daniel
Edited by HoBi
very nice and priced well
If I didn't have one I would be on a plane to check it out in person
GLWS - (oh and black is sexy)
Edited by Sinista32
  • 3 weeks later...
  • 8 months later...
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
