Not so far but to be fair i havent really played with it to check.... They were brand spanking and still had writing on them so let me bed them in and ill check back in!
Actually on that note, i will know by the end of Sunday as its doing the Nulon Nats event :woot:
I'm sure it's the same for most tyres as the ad08r requires about 100km of driving to wear off the top shiny coating before the grippy part comes into play
  • Replies 54
Oh FFS then i better do some K's before it goes on the trailer this weekend then!
They look pretty bulgey compared to the old 275's i ran... You can see the difference between a 255RSR and a 275 RS3
If anyone wants the other pair of the 275/35/18 let me know... Will sell for what they cost me but i had to buy 4 to get the deal...
Brand new with stickers $512.50 for the pair :laugh:
Freight additional!
There was no magical grip that i was hoping for... 2nd gear is still skidsville BUT it was a road surface so it is not the best indication at this stage!
1265536_700169503374776_1002666072_o_zps
What tyre pressure and camber? They can affect the grip level as well
Yep, i was running 0 camber but it is now up to around -1.4 or something like that for circuit use.... In saying that i went from a 265 to a 275 in the hope the straight line contact patch would remain similar, but probably not lol
Pressure was about 30 hot so a bit low from a standing start.... But i did warm them up prior -
  • 1 month later...
That's a damn good price for 275 35 18!
I'd only put KU36s back on if Maria and I are having a domestic ;)
Lololol so you cant hear? Brilliant!
Oh and i changed my opinion on the RS3 too once i had them hot on the track, great tyre!
Told ya so Matty! :D
The rears had heaps of corner grip... Straight line had issues but i had it turned down to gate pressure for the run anyway...
After a few hard laps of South circuit the fronts (Federal RSR) would start to understeer yet i still had heaps of rear grip and no signs of it fading!
Its impressed me enough to step up to the next level of Hankook ;)
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
