Yea got it from a 180 same as a s13 need the wiring aswell all the wires have to be re arranged to suit not that hard took 20min start to finish to have it all wired up and working couldnt find a write up but was pretty straight forward to work out wire placement between both looms
https://www.sau.com.au/forums/topic/441231-my-a31s/page/2/#findComment-7396217
Not as easy as it used to be but do come up wrecking from time to time just have to find someone that is willing to cut the subloom thats hard wired into the dash loom thats the hard part
https://www.sau.com.au/forums/topic/441231-my-a31s/page/2/#findComment-7396853
  • 3 weeks later...
Hks filter on
The steering bush I made up
Period era nismo brace fitted up
greddy kit
Small amount of wiring to get the cluster working fully but totally worth it
made a full loom so looks factory
Kinugawa braided lines
HKS oil and oil filter
https://www.sau.com.au/forums/topic/441231-my-a31s/page/2/#findComment-7406041
Pulled rear out and switched it over to a r32 5bolt lsd and completely removed hicas and fitted steering lock spacers
Decided the s1 front bar and lip weren't cutting it anymore so went to a s2 front bar and put lip on that
put the boot badges back on
and when you say to a 2 year old want to help dad on the car this is the outcome lol
only few small things to do left to get it ready then it will be on a boat on its way to aussie so should be seen on the streets in wa early next year then I can start building up the car lol
https://www.sau.com.au/forums/topic/441231-my-a31s/page/2/#findComment-7406042
  • 1 month later...
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
