Ok starting to clear out the garage of all the bits and pieces I've collected over the years.
Getting my car ready to sell and have new business venture and baby on the way, so will be getting rid of everything so more coming in next few weeks as time allows.
N1 CRANKSHAFT : $400
Great Condition. Was going to be used for another project but got to go.
Pick up or can organise delivery Oz wide at buyers expense. E-go would be very cheap.
R34 GTR RIMS : $900
Standard R34 GTR rims In good condition but 1 rim has a few scrapes but would make good track rims or easily repaired for set of good rims.
Pick up or delivery Oz wide at buyers expense.
ENKEI RP05 RIMS : $2900
I doubt there is another set of these in Oz. Bought these in Japan for my car and have very little use and are in excellent condition.
These are the Silver type. Pretty sure they are 18x9Jx 25 as I ran these with spacers but I'll check and confirm.
On my Car in Japan
All prices slightly negotiable and I'll get pics pf other parts up asap.
Rims are located on the Gold Coast.
Pics will be sent to guys who have contacted me.
I'll load up pics here later today/tonight.
Delivery to SA around $50-$60 max.
:whistling:
  • 4 weeks later...
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
