  • 3 weeks later...
  • 4 weeks later...
bamp
still for sale
included with the price, free high fives all around, followed by a group hug.
if it's just the two of us, it's no longer considered a group hug. just a hug. or an embrace, depending on chemistry.
  • 1 month later...
  • 3 months later...
Where abouts is it, man?
As title says, full exhaust for R32 Gtst
From the turbo back, so includes 3 inch dump pipe, high flow cat and 5 inch cannon.
Located in Bellbowrie
Pickup only
$300
pm me
I'm guessing it's in Chambers Flat. :huh:
  • 4 weeks later...
  • 3 weeks later...
  • 3 weeks later...
