Added :
R33 rb25det motor comes complete $1400
R33 rb25det Gearbox $1000
Diff $200
Tailshaft $100
Xforce Exhaust $250
5 stud with brakes hubs etc $550 front and rear
have other spare parts too as it is coming off r33 with front end damage
R33 Guards Drivers side slight dent at bottom $100
R33 Front Reo $100
R33 Rear Reo $80
R33 Boot with spoiler $80
R33 De Cat $50
R33 GTT Ems Stinger 4000km $400
R33 Greddy Fmic 4000km $400
R34 GTR Nismo Side Skirt's and Rear Pods $500
R34 GTR Rear Diff V spec 35,000km $650
R34 GTR Power FC D-Jetro $1000
R34 GTR Stock Air Box $300
R34 Gtt Front Guard's Athletic Silver $450
R34 Rear Spoiler Jun Legs CF spoiler blade $500
R34 Xenon Headlight's perfect condition $1000
R34 Gtt Front pipe $50
R34 Gtt Rear reo $80
R34 Lenso wheels with 50% tread $900 18x10 +35 all round
R34 Tail Lights Athletic Silver $400
R34 Athletic Silver Side skirt's $250
R34 Radiator with shroud $120
R34 Z tune front bar in Fiber Glass $500
R33 Passenger door complete blue \ green colour $100
R34 GTT passenger and drivers door complete $350
R34 GTT series 2 motor non turbo has CAS missing and a few other bits - $400 or can strip parts of it
added
R33 Xforce Exhaust $250
R33 Manual Diff $200
R33 Tailshaft $100
R33 rb25det motor comes complete $1200
R34 GTR 2860 -5 Turbo's 10,000km old Comes with HKS actuators and dump piples $1800
  • 1 month later...
  • 1 month later...
R33 Front Reo $100
R33 Rear Reo $80
R33 De Cat $50
Added :
R34 GTR Front Splitter Carbon Fiber $620
R34 GTR Jun Spoiler Stands Carbon Fiber $260
R34 GTR Spoiler Blade Carbon Fiber $270
  • 1 month later...
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
