hey i just bought a r32 skyline gts-4 and im just curious what are the best yet not too pricey mods i should do to it???
i was also curious what parts i can swap straight over from a gtr like brakes or ??? trying to save a bit of cash haha..
also i was wondering if i was to upgrade the turbo which would be the best turbo i could get for a good price?? dont mind second hand ones either??
https://www.sau.com.au/forums/topic/44315-need-help-with-mod-choices/
Finish exhaust if u havent? i.e dump/front - $300+-
Then CAI (pod etc) - pretty cheap depending what brand or custom made
Electronic Boost controller or manual bleeder - from $50 to $800(e-01) etc
Piggy back ecu - either emanage or safc? chipped ecu even from $200 to $500, controls timing ignition and fuel maps for larger gains
They are the above 3 reasonable cheap mods which will get you largest gains then you step into another sorta stage:
Larger Turbo
FMIC
Injectors
Standalone ECU - motec autronic power fc
fuel pump, afm etc etc etc
Suspension work
list goes on...
Best thing is to use the search function mate...threads everywhere!
Best most popular turbo depending on how much u wanna spend...
Well u can either highflow...or just buy a HKS 2530 2535 2540 or similar, straight bolt on so u dont have to change wastegates etc...not sure on outputs but ur looking around the $1500 to $2000 for 2nd hand or high flowing
Once again their are tonnes of threads in Forced Induction Forums covering best turbos for every type of budget and power output required
isnt the gts-4 a non turbo all wheel drive ???
anyways what blade said is spot on if $$$'s are limited nice flowing exhaust (full exhaust), pod filter possibly try advancing the timing if you are careful it can reap some small rewards and yea depends on what you want to spend mods are only limited by your budget.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
