I have a bunch of r33 parts sitting about that need to go.
Description:
R33 S1 headlight in great condition not faded with all brackets intact.
Price: $150 each pickup shipping ontop
Description:
R33 S1 type M front bar. Bar is silver it has never been cut for an intercooler and needs a repair finished to make it A1
Price: $100 pickup
Description:
R32/33 stock front pipe and cat
Price: $50 pickup
Description
R32/33/34 s13 xforce high flow cat
Price: $50
Description
Rb20/25 low mount stainless turbo manifold in need of tlc
Price: $25 pickup
Description
R32/33 stock cat
Price: $25
Description
R33 front reo support. It's been cut for an intercooler.
Price: $50 pickup
Description
R33 plastic engine under tray
Price $25 pickup
Description
R33 climate control
Price $25
Description
R33 option parcel shelf air purifier
Price $20
Description
R33 new moulded boot 12" sub box fits nicely on the driver side and is covered in the same material as the boot lining price off the shelf was $250.
Price: $150 pickup
All parts are located in Pakenham south east Melbourne
Contact via pm or 0438804282
Would have liked to sell the pair but yes can have it for $150
Let me know on the climate and manifold
Not sure if it's you mate but had a full price offer on passenger side just waiting on payment
  • 4 weeks later...
  • 4 months later...
  • 3 years later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
