OK, here's what's pissing me off... I normally get about 400km out of a tank, with half a tank gone I normally manage 270kms and only get the 130km out of the rest which doesn't make sense :chairshot
I gather the fuel gauge isn't that accurate, does anyone else's r33 do this?
Does anyone have an aftermarket electronic fuel gauge installed? If so, can you recommend one to buy.
:cheers:
Kyran.
https://www.sau.com.au/forums/topic/44379-fuel-gauge/
Ummm... In simple terms...
Open boot.
Remove plastic battery / boot seperator...
Unscrew 4 screws holding metal fuel tank cover...
Disconnect all hoses and electrical connections...
Unscrew fuel tank jar lid using the service tool (pffft) or a block of wood and a hammer...
Find fuel sender float floating in tank...
Replace on mount...
Reverse and repeat...
Not 100% but pretty close... This is off the top of my head... Plenty of topics around about how to do it though...
https://www.sau.com.au/forums/topic/44379-fuel-gauge/#findComment-907457
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
