r34 gtr oem strut brace will fit r33's excellent condition $100.00
r34 gtr factory radiator and shroud excellent condition $200.00 will separated if need be
r34 gtr factory injectors 444cc i believe standard rail available - $250
r34 gtr oem coilpacks - $150
all parts work perfectly and came out of r34 gtr 60000km make an offer
located parramatta nsw, txt 0450428895 will post at buyers expense
  • 3 weeks later...
Hey mate,
Have you had any issues with the coil packs?
Thanks
hey champ
no never had an issue with these coil packs on my 300awkw r34, i just bought a hole new ignition system when i rebuilt my motor, oem packs are insufficient for the power my car currently makes
cheers
  • 3 months later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
