Hi all,
I was wondering what kind of injectors i would need to suit my current setup, my current mods consist of:
BMC Airfilter with Heat Shield
NGK Iridium Plugs
FMIC
Turbosmart E-Boost
3" Exhaust with Dump Pipe and Hi-Flow Cat
Greddy Plenum
Bosch 040 (I think) Intank Pump
My turbo just died and i have purchased a new turbo, it is a RB25 turbo that has a new Ball Bearing T3/T4 Core good for up to 22psi. I know that with my stock injectors and computer i wont be able to run this turbo at its full potential. However i am buying a Power FC and i am buying injectors to.
My Question is, because i have the Greddy plenum i can get a GTR Fuel rail and run top feed injectors, would the 444cc injectors from a GTR be sufficient to run this turbo at full boost or would i need bigger injectors then these again? My aim is as much power as i can get from this current turbo and setup, all help is much appreciated, thanks
https://www.sau.com.au/forums/topic/44394-what-injectors/
Hi all,
NGK Iridium Plugs
FMIC
Turbosmart E-Boost
Greddy Plenum
What engine is this?
https://www.sau.com.au/forums/topic/44394-what-injectors/#findComment-907989
ive been told a good rule of thumb is look at what horsepower you would like to achieve then match them with the same figure injectors. eg 550 hp then get 550cc injectors etc
i was actually discussing this tonight with a friend and this is my theory:
If my 6cyl rb25 flows 550hp of air and need a total of 3300cc of injectors (6cyl x 550cc) will my 4cy sr20 which also flows 550hp of air need a total of 3300cc of injectors? yes. so that means it would need 4 x 825cc injectors (3300cc / 4cyl).
sustained air fuel ratios is what im keeping in mind. i think i am right in what i am saying :s im not too sure so correct me if im wrong :)
https://www.sau.com.au/forums/topic/44394-what-injectors/#findComment-908132
sustained air fuel ratios is what im keeping in mind. i think i am right in what i am saying :s im not too sure so correct me if im wrong ;)
You got it. :)
https://www.sau.com.au/forums/topic/44394-what-injectors/#findComment-908134
oh sorry, its an RB25DET. Well at this stage i think anything over 300hp at wheels would be nice, i spose the best i can get above that is what im after, if the turbo does 22psi what kind of power will i be able to achieve with the injectors and power fc before the internals become at an unsafe point?
https://www.sau.com.au/forums/topic/44394-what-injectors/#findComment-908164
Firstly you need to remember that boost is simply a measure of restriction to airflow. It is airlfow itself that makes power, boost is really irrelevant. If you remove the restrictions in your engine, then you can make more power at lower boost. :idea:
Moving on to your question, 300 rwhp is ~225 rwkw and that is pretty much the limit of the standard injectors. RB25DET internals seem to handle ~300 rwkw (400rwhp) as long as the tuning is spot on. There are a number of threads on this subject, you really should do a search. :)
https://www.sau.com.au/forums/topic/44394-what-injectors/#findComment-908184
one more question, will the standard injectors and computer with that turbo get my 300rwhp?
With this information........
you expect me to be able to tell if the turbo is good for 225 rwkw? :wassup:
Sorry I can't do that, there are at least 20 different combinations of T3 and T4 turbines & covers and compressors & covers. I have no idea which set the turbo builder has used. Since they have gone to the trouble (and expense) of doing a ball bearing hi flow then chances are it is a worthwhile upgrade. My best suggestion would be to find out who did the work and ask them, they should have a record via the turbo serial number. :)
https://www.sau.com.au/forums/topic/44394-what-injectors/#findComment-908435
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
