So you reckon its the bov spring, not the gasket? Can I not put a new similar rated spring on - also if I block that little hole, there will be no boost getting in from the top to hold the bov shut - hence it will always be open/ leak, correct?
Ok don't smash it. Caress it with a hammer.
Like I said to increase the spring preload.
It fixed my bov leaking which is your current Issue
Also block up the little hole with a m5 grub screw.
or think about it for weeks and do nothing. Doesn't bother me.
man you are a wet blanket sometimes ay.
  • Like 1
Have you looked at the stock bov?
You can't replace the spring.
The hole I'm talking about is on the side that bolts onto the crossover pipe. It does not help keep the valve shut and it's very common to block it.
It is there to smoothen the transition onto boost.
And one more time.
I did it.
It fixed my bov.
It doesn't leak.
I run 20 psi.
Anyway. I'll stop being a wet blanket and trying to help you.
Ben is right. I blocked the hole. I then beat the top of the bov in. You get less travel on the (piston/hat?) but it's firmer now.
When you take your foot off the accelerator It will flutter a lil under light boost, and make no noise at high rpm. It's perfect.
We've all had the same problem of boost leaking in the low end. This fixed mine.
Edited by Stagea97
  • Like 1
Thanks fellas. I will insert a screw in that hole and try to punch the top in with a hammer, just fear damage that it won't open anymore.. Anyone got a pic of a bashed in bov, so I know roughly how much to 'do it in'?
I run 22psi btw, and at 22psi in 3rd/4th it drops and keeps dropping down to 12-13psi sometimes, not all the time - and boost fluctuates 2-3psi most times. Definitely a leak.
Edited by rondofj
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
