Hi guys/girls, I recently went through a box of car parts and came across the factory ecu that came out of my Series 2 Stagea Autech 260rs and noticed the ecu has nismo factory sports resetting stickers on it. I've tried searching the forum here and also google but cant seem to get any decent answers as to what the sports resetting did/changed etc. Can anyone help?
Thanks
The Nismo sports resetting ECU is a factory unit that has been tweaked by Nismo, my mate has an S1 350PS version in his R34.
Basically it removes the speed limiter and raises the boost to 1 bar as far as I know, so a very light tune for a standard car.
Ahh I see. So in saying that would it still increase boost to 1 bar with boost restrictor still fitted?
I take it this wouldn't be a bad option for a car fitted with just a front pipe back 3" exhaust then?
Would there be much point cost and performance gain wise buying something like a power fc or getting a nistune done with only exhaust upgrade?
And does anyone know whether these 'nismo sports reset' ecu's can be nistuned?
Thanks
I wouldn't count on anything with an unknown ecu. If you have limited mods then plug it in on a dyno and see how it goes???
If your planning to plug it into your r34gtr then I wouldn't.
Most of the time you can't nistune a 'tuned' rom ecu from Japan.
I would buy a nistune for your current ecu and have your car tuned by a professional, with your fuel of choice, to suit the intended purpose and climate. You would see some solid gains even with just an exhaust with a decent tune.
Cheers
J.
Fair enough. Yeah I could try that I guess. I just figured all the nismo factory resetting would be the same tune for all of them being apparently only 1 bar of boost as opposed to factory boost pressure. Im guessing that a little extra boost is all you really get with it as the speed limiter removal isn't really a gain. In saying that the boost is increased to 1 bar, why is there so much debate on removal of the boost restrictor being 'risky' considering it increases the boost to roughly 1 bar too so if nismo are happy to do it from the factory as a reset, you would think it cant be too unsafe?
Any idea on what the general cost of a nistune should be?
Not all nismo tunes are the same, you wont know what the timing, fuel or boost parameters are until you try it.
1 bar is normally considered pretty safe on a stock tune... it just wont be ideal in terms of tune.
Nistune is around 400 for the board and 100 for install plus tuning.
Actually, with the RB26 Nissan pretty much always intended it to run 1 bar boost, and the ECU was pretty well mapped for it. The boost restrictor is really only installed from the factory in order to pay lip service to the 280ps gentlemen's agreement that the Jap manufacturers had. That's one reason why the restrictor was marked on the hose with a line - to make it easy to find and remove once the car was bought and no longer subject to the gentlemen's agreement!
Pretty much everything about the RB26 was intended to be a 400 HP engine, including the tune.
The Nismo maps might be slightly different - but I wouldn't be surprised to find that the 1 bar boost on the Nismo cars with that ECU was courtesy of a different (removed) restrictor rather than anything in particular with the tune. And because it was Nismo, and therefore effectively Nissan, I wouldn't be surprised if the ECU was Nistunable. I wouldn't spend money to find out, but it would be a reasonable bet.
Thanks for the posts guys, interesting stuff.
To me it seems that 1 bar boost wouldn't be possible via a 'reset' ecu if the boost restrictor is fitted anyway would it?
One would have thought the 'reset' tunes were all the same from factory as the cars would all have been sold with the same factory setup in regards to exhaust etc unless nismo exhaust systems were a factory option which the ecu's were reset according to if these options were fitted for the buyers.
Any opinions on whether getting a nistune board fitted and a custom tune as opposed to even a used power fc would be more beneficial as I imagine the tuning time and costs wouldn't be much different and ive seen power fc's and hand controllers sell as low as $600/$700
Edited by livewire
If you've got the stock snails run the stock ecu. Pull the boost restrictor out though.
Also these cars are old now, no denying that. Get it checked on a dyno incase the AFR's aren't acceptable or if its knocking. Also get them to set your base timing while you're there.
That way you will know for sure if its safe to run that jap-tune which are often quite knife edge in terms of timing.
Plus you'll get a sweet dyno sheet to show your facebook mates how big your dick is
Thanks for the advice. Yeah. Definitely wouldn't go just chucking a reset ecu in and driving round hoping for the best. Was just wondering whether they were all 'reset' to the same specs and can't quite see how an ecu would adjust boost pressure with the restrictor still in place. Might remove boost restrictor at a workshop and get it put on the dyno and get the shop to try both ecu's and see if they can tell what differences they can pick up in the nismo reset one as opposed to factory untouched one.
My mate's 34 GTR came with the sports resetting ECU which other than that was completely stock. We did some testing and it does indeed run 1 bar with the restrictor in and up to 1.2 with it out.
I'm fairly certain R34s run 0.95 bar standard, my R33 runs 0.85 so 12.5 psi and around 13.5psi respectively.
The sports resetting "S1" unit supposedly is setup for 350ps but which isn't much more than stock but it's something. I'd say with minor mods the benefits increase, there might be some slight mixture or cam adjustments but they would be very minor I imagine.
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
