Hi there boys and girls up for sale is my nismo ecu. I'm selling it due to lack of funds for getting it tuned right for my car at the moment and thought it could go to a better home of someone looking to go the next stage on there stagea.
Price $1200 Ono.
Pm me if interested
https://www.sau.com.au/forums/topic/445650-m35-nismo-ecu-for-sale/
anyone know the difference between impul and nismo ecu as i have a impul one ?
sorry to hijack thread thought keen buyers may answer
The Impul ECU has no safety restrictions so basically if you put a different turbo on and wind it up it will let you blow the motor.
The Nismo ECU gets rid of a lot of the throttle lag, changes the drive of the car so thats its sportier, it also replaces the snow map with an eco map and gets rid of the speed cut.
  • 2 months later...
Are these Nismo and Impul ECU's for the turbo models only?
There are non turbo ones also. They are tuned after market for the car they are on. I'm not sure if it is still there but there has been a non turbo vq25 nismo ecu on import monster for a while.
It's very important that you get the right one.
No doubt. I have an NA VQ30DD so that 2.5 one wouldn't work for me. Osiris (USA) won't do a tune on my ECU either. Any other suggestions?
We have teh same issue in australia where there is no option to have the standard ecu flash tuned. We have resorted to stand alone ECUs like f-con or adaptronic(what i run) or piggy back systems like the Greddy Emanage ultimate
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
