Gday all. Lately I have been losing my power steering. Sometimes the car will start with the power steering working and then it will conk out (power steering stops working while drviving)..I can still drive like this but Im sure its not good for the car drving without power steering. Other times it wont work as soon as I start the car.
THis has been happening since the HICAS light has been appearing now and then on the dash.
So far I have checked the obvious things. Power steering fluid, HICAS connections underneath car and the HICAS fuse.
My car is an R33 gtst.
Anyone got any ideas?
cheers
https://www.sau.com.au/forums/topic/44583-loosing-my-power-steering/
Had a problem with my Hicas computer under the rear parcel shelf.
The compliancer got it wet (don't know how).
It had the same symptoms as yours until I dried it out and it started working again.
So I'd say check that computer first.
If the steering pump is turning without fluid spewing out it's unlikely to be the pump I'd say
Good Luck
  • 6 months later...
going to have to resurect this thread guys. The problem I was having with losing the steering disapeared not long after posting the previous post. THe problem has now come back. Basically when the hicas light comes on I lose power steering but it can come on and off at its own will which is quite dangerous when turning corners obviously.
Can someone please help with this. I have tried a hundred and one times to get into diagnostic mode and just cant seem to do it.
cheers
  • 4 weeks later...
hmm... I'm actually having a similar problem. It started with driving with my dash taken off. Power steering would work for a while, then stop working, then hicas light would come on. Once I put the dash back together, it went away.... Now, some months later, its happening again. Power steering will turn off after about 10 mins of driving, and hicas light will come on in a further 5 mins. Im stumped :P
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
