On my 2004 Nissan Stagea 350RX where does a OBD 2 scanner plug in, and if I buy a scanner what brand would be a good suggestion, I see hundreds of them on Ebay, what am I looking for, they seem to start at about $20 up to $180.
Cheers in advance Harry
https://www.sau.com.au/forums/topic/445834-obd-2-scanner/
I thought the 350 would work with any OBD2 scanner, as it was made after mid 04 when the OBD2 laws came out in Japan.
You would still need the Consult 3 for detailed diagnostics on all the ecu's in the car, the generic ones would only pick up the engine I think.
Where are you located Harry? Someone local might have something you can try out before you buy...
https://www.sau.com.au/forums/topic/445834-obd-2-scanner/#findComment-7344562
Hi Scotty, I am in Wellington, New Zealand. New to the Stagea thing, I have an engine light on and want to learn more about all this, the engine has to crank over about 6 to 8 times cycles before it starts, from what I have read on here it probably is a cam angle sensor. I have rad the manual way of reading codes, just have not tried it yet.
Thanks for your help.
https://www.sau.com.au/forums/topic/445834-obd-2-scanner/#findComment-7344659
Either crank or one of the cam sensors is faulty. Have you tried cleaning them? Sometimes metal shavings from the starter motor build up on the magnetic crank sensor as it is at the bottom of the bell housing, this can cause issues with starting.
https://www.sau.com.au/forums/topic/445834-obd-2-scanner/#findComment-7344997
i have a obd2 scaner creader i believe the name is and it talks just fine to the stags i just use the infiniti option and automatically select car it does o2, maf as well as helped me work out which abs sensor was dead
Very interesting. Can you check the exact model for us guys? does it clear codes properly? Would love to see if i could clear my airbag light with it. Would be worth every cent.
https://www.sau.com.au/forums/topic/445834-obd-2-scanner/#findComment-7351577
http://www.ebay.com.au/itm/2014-LAUNCH-Creader-VII-Auto-Car-OBD2-Code-Reader-Scanner-Engine-Airbag-ABS-/201094900479?pt=AU_B_I_Electrical_Test_Equipment&hash=item2ed230aaff&_uhb=1
that is a ebay link
and here has more details on various types
http://www.launchtechusa.com/assets/products/products.html
I cant vouch for doing a airbag light but has worked on my fathers land rover a subaru and a bmw i have used it on so far my model is Viii+ but for its price its awesome home workshop addition
  • Like 1
https://www.sau.com.au/forums/topic/445834-obd-2-scanner/#findComment-7352282
  • 4 years later...
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
