Hi all,
I have a bit of stuff laying around my shed I would like to sell as im tripping over it.
There is a mixture of R32/R33/R34 Gtr parts as well as R33 Gts-t bits.
I have taken pics of most of the parts advertised & some pics have multiple parts in them so I
could fit it all in.
**R33/R32 GTR & GTs-t Body Parts & Running Gear**
1-R33 Gtr Non V-Spec rear Lsd with matching drive shafts complete as a package -$750
2-R32 gts-4 front and rear diff gears 4.3 (hard to find these days) makes a great improvement for response and lower lap times on your R32/R33 GTR. Rear diff is still together, as pictured I have the front diff out of the sump assembly so I could inspect it. These diffs came from the same car that had done 86,000klms.Perfect condition $600
3-R33 Gtr N1 front bar. I bought this in Japan and was off a Gtr33 endurance car.It has the Nismooil cooler vents on both sides (simular to the Nismo 400r front bar).Its got the Nismo intercoolerducts (minus the actual ducts,u can buy em for $120 a pair),also has provision for a tow hook. Another cool feature is the lines for several water squirters on the oil coolers and intercooler. Its got water squirters from a bonnet placed strategically on the inside of the bar (as pictured).All you gotta do is hook up your window washer bottle and re route the windscreen washer water to the front bar cooling squirters with a $1 t-piece. So when you pull your stalk towards you for thewindscreen washer water to clean your screen,it instead sends water onto the coolers.
It works fantastic and dropped my temps down by as much as 10deg after 3 laps flat out at
lakeside. The standard series 1,2 & 3 lip bolt straight up to it.I havent seen another bar like it. Sell $550
4-R33 Gtr front bar corner indicators-1 pair with standard indicators (left & right) $100
2- Second pair with (L&R) with passenger side indicator only $65
3-Thirdly drivers side only with Nismo clear indicator lens $35
5-R33 Gtr/Gts-t factory rear bar (silver) -$135
White rear bar (needs paint)-$75
6-R33 Gtr/Gts-t rear bar rio -$100
7-R33 Gtr/Gts-t rear tail lights complete set white pair (qm1) $200
-silver pair (klo) $200
8-R33 Gtr factory side skirts left & right side with 1 front pod (I cant find the other side)-$175
9-R33 Gts-t factory side skirts. I have 2 pairs (as pictured) a pair -$175
10-R33 Gtr factory series 1-2 headlights. I have a matching pair & they are perfect,crystal clearno blemishes-$350.
I also have 1 only passenger side I was going to gut it to make a direct intake but it never
happened. This single headlight is crystal clear as well. I will do a deal on all 3 headlights for$400 or if u want the passenger headlight on its own $150.
11-R33/R34 Gtr complete factory struts (front & rear) good condition $250
12-R33 Gtr abs unit -$200
13-R33 Gtr factory Pwr steer reservoir -$40
14-R33 Gtr strength plate x2 (located in the boot that covers the battery etc) each -$50
15-R33 Gtr 4wd Atessa pump & reservoir & lines (off v-spec)-$200
16-R33 Gtr factory side indicators (L&R) pictured in Nismo boxes, pair $10
17-R33 Gtr factory floor mats, rear section only. Has a stain on 1 of them (see pic) but im sure with a scrub it will come out -$70
18-R33 Gtr factory tool kit & jack -$100
19-R33 Gtr Gts-t? Series 2 airbag dash with series 2 airbag steering wheel,glock spring indicator stalks ,passenger airbag etc.Everything you need to get you going. Dash, steering wheel etc in
excellent condition (see pics) complete package-$600
20-R33 Gtr/Gts-t series 2 airbag steering wheel with all necessary bits complete $250
21-R33 Gts-t manual dash cluster showing 82,000klms -$145
22-R33 Gts-t factory ecus.From memory there is a series 2 ecu,the other is a series 1 ecu and the3rd one im not sure what that is? Numbers and plugs as pictured so you can match up yours.
each -$100
23- R33 Gtr /Gts-t rear parcel shelf with factory kenwood speaker covers. Theres a small hole on both speaker covers as my coilover adjustment rod went through them. -$30
24-R33 Gts-t series 1 whole car wiring harness .I think its 100% complete but I cant remember?
(as pictured in 2 boxes)the lot -$150
25-R33 Gtr starter motor-$65
R33 Gtr alternator-$65
R33 Gtr ac pump $75
26- Various R32/R33 Gtr /GTS-t,Rb26,Rb25 starter motors, ac pumps (I can email detailed pics for matching numbers & brands)-$40 each!
Various R33 Gtr/Gts-t washer bottles & radiator reservoir bottles,each- $10
**EXHAUST BITS**
1-R32/R33/R34 Gtr Rb26,Stagea Autech, Hks dump pipes. These have been heat wrapped -$350
2-R34 Gtr factory Dump pipes (fits R32/R33/R34 Gtr Stagea Autech as well).These will never crack& I ran these on Gtr 33 and made jst over 500 hp @ all 4s.$300
3-R32/R33/R34 Rb26 GTR/Autech Stagea Trust front pipes. A little scrape but doesnt affect
anything. Heat prof Painted -$250
4-R33 Gtr standard factory Calsonic exhaust with standard factory front pipes. This Complete
exhaust was off a 1997 Gtr. Comes with compliance cats already installed. Good for a spare system
or in case you need to do an emissions test,maybee u wanna turn your monsta back to standard.
Or if u want to swap a cat back 3.5inch system for this im happy to do that.Complete set $375
5-R33 Gts-t factory cat back exhaust.Calsonic brand and ready to bolt on.- $200
6-R32/R33 Gtr factory front pipes. I have 2 of these and both good condition, each-$95
**R32 GTR PARTS**
1-R32 Gtr complete set front & rear interior door trims. Great condition as pictured -$350
2-R32 Gtr factory steering wheel GTR horn button. I have 2 & both are as new condition,each $100
3-R32 Gtr Jun front lip. Made in Japan -$175
4-R32 Gtr/Gts-t factory stereo brackets -$100 or with Alpine CDA-9851 mp3/cd player as pictured
with brackets -$200
5-R32 Gtr factory front intercooler grill -$80
6-R32 Gtr custom intake air box (use with pod filters).Made from alloy, brand new never used $80
7-R32 Gtr Sony 10 stack cd changer control. These were an option on the GTR and located in the
centre console. Where do u find 1? I dont have the actual cd 10 stacker cartridge. As pictured ingood condition but there is a slight black mark in the lcd screen (doesnt affect it working).Thiswas working perfectly when pulled out of the car. -$100
8-R32 Gtr left hand side mirror factory mirror. Gunmetal grey,in great condition $45
7-R32 Gtr/Gts-t factory floor mat sets.1 set drivers side missing $50
Set 2, rear section only $30
Set 3, also rear section only $30
Everything is available for inspection or pick up on southside of Brisbane.
Interstate buyers I am happy to post/courier etc for you but at your expence. I use the cheapest
couriers www.e-go.com.au and I can quote you on shipping.
Everything is wrapped and ready to send. I need this stuff gone asap as im moving and I dont wantto take these bits with me. I am open to reasonable offers.
Prefer phone contact/sms 0452-389-598
Edited by BIGBOSS
https://www.sau.com.au/forums/topic/445885-r32r33r34-gtr-r33-gts-t-bitz/
Ok, here's an update on what's been sold
-R32 Gtr Custom Air box
-R33 Gtr head lights pair (left & right) I still have the passenger side left $150
-R34 Gtr factory dump pipes
PRICE DROP ON THESE ITEMS BELOW
R32 Gts-4 front and rear 4.3 diff gears Were 600 now $500
R33 Gtr non V-spec lsd with matching drive shafts was 750 now $650
R33 GtrN1 Front bar was 550 now 450
I have gotta clear this stuff outa my shed asap as im moving and I have no room to put it anywhere. Make a reasonable off on anything you never know.
:thanks:
Sorry no grill or bonnet for r32.
UPDATE ON WHATS BEEN SOLD
R33Gtr front bar
R33/34 Gtr suspension
R33 Gtr side skirts
Make a reasonable offer on anything else guys I really need this gone.
Best to get me on 0452-389-598 for a quick response :thanks:
  • 3 months later...
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
