Hi Guys,
I have up for sale a few parts i will no longer need...
Par 5 speed straight cut dog box for R32/R33 GTR $5000
Selling due to a change of plans, holds around 600kw no problem comes with upgraded Holinger input shaft , billet selector forks and a ogura type tripple plate clutch, the box has been recently inspected and will provide the report upon the sale , can of gearbox oil also included.
Gandaor Mirrors R33 GTR only ( as far as i know) $450.00
Decided to keep my original ones, i bought them from the forum and just sat around taking up room, minor scratch on the right lense.
HKS EVC 5 boost controller $300.00
Had this as a spare boost controller, no longer need it.
x2 HKS Turbo Timers $30.00 each
Again, i have these things everywhere have to get rid of some.
R33 GTR shocks and springs $200.00 ( no tops )
Car has coil overs.
R33 GTR genuine weather shield. $80.00
Replaced them with a set of after market due to condition
R33 GTR power steering cover $50.00
Replaced with a custom made one.
All parts located sydney and would like to make local sales if possible , if you have any questions please pm me , Thanks!
post-1164-0-07762400-1407040686_thumb.jpgpost-1164-0-42365600-1407040704_thumb.jpgpost-1164-0-04323100-1407040714_thumb.jpgpost-1164-0-48695900-1407041926_thumb.jpgpost-1164-0-58802700-1407041934_thumb.jpgpost-1164-0-90600800-1407041939_thumb.jpgpost-1164-0-28115100-1407041998_thumb.jpgpost-1164-0-26788800-1407041374_thumb.jpgpost-1164-0-70020100-1407040942_thumb.jpgpost-1164-0-05114600-1407041067_thumb.jpgpost-1164-0-06599100-1407041203_thumb.jpgpost-1164-0-12114700-1407041228_thumb.jpgpost-1164-0-75802800-1407041297_thumb.jpg
price drop!
R33 GTR shocks and springs $150.00 ( no tops )
R33 GTR genuine weather shield. $50.00
R33 GTR power steering cover $30.00
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
