hey, like they say if you dont like it go else where im not forcing you to buy it. Im posting it for sale for those who are interested. I dont have a whole wardrobe to off load. I do have contacts where i can get these shirts. I dont have a whole heap of stock i take peoples sizes and orders and then i get what they want simple. If you have a problem with my post take it up with me personaly dont go posting negative info on my thread.
Was considering it if genuine. But a cheap rip off...Nahhh.  I'm sure you could get a genuine one for around 120.
Dont be fooled, most of the stuff you think you are buying thats made in japan is made in china but marked up and sold in japan.
Bit pricey for just a t-shirt tho.
How bout $80? I will take one for that price coz they cost bugger all to make in china.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
