Wanted: Old 5X114.3 Brake Disc - Pickup In Melb
Hi guys,
I'm building a coffee table with a 20x12 Ferrari 458 wheel. I want to bolt a brake rotor to it for visual effect.
So hoping someone has an old disc laying around they don't need and would be happy to donate to the cause.
Doesn't matter if it's warped, lipped, rusted etc....I'm just going to paint it and bolt it to the wheel.
It's a 20" wheel so the larger the better, slotted, drilled, or two piece floating rotor would be ideal!
Preferably for pick up around Melbourne.
Cheers
Mat
I've got a DBA4000 Slotted 294mm rotor (R33 Turbo front rotor size) that's been scored up a bit by a crumbling brake pad. Replacing them, so it's no use to me anymore... I think it'd look pretty tiny inside a 20" wheel though.
Consider it a backup option if you need it...
Good idea! I guess on that note, I could probably ring Lance Dixon and see if they've got any old ceramic rotors laying about !
I guess I just though a Nissan forum would be easier as the 458 has a 5x114.3 PCD - which is pretty unusual for a fazza.
Must be so the Ferrari owners are able to run mid 90's japanese rims with sick offset and put stanceworks stickers all over it.
Edit: Kill me now...
  • Like 1
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
