  • 1 month later...
haha lol ^^^^^ yeah dude on a 34 you want at least 18" but like terry said.. you might aswell pack your lipstick in the centre console! the guards and arches are bigger so at least 19" on a 34GTR 19x10.5 +15 as a minimum!
well no one specified GTT or GTR
IMO each of the cars look like the era they were designed in and there. 18's don't suit r32's, they look like the 80's and 19's and 20's don't suit r34 GTT's
the rubber band tyres on that blue r34 posted earlier look ridiculous to me
Edited by mystery_kid
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
