R34 gtr windscreens front and rear $400 each, genuine.
rear quarter windows $300 each
will fit gtt 2door also
doors with window and window reg $350 each
mirrors $200 each
door handles $50 each
door cards front and rear good condition $700 the lot
aircon condenser no leaks $100
thermal fan $70
xenon headlights $1000
front quarters $600
ganador titanium exhaust has a big dent but could be cut and repaired $300
fiberglass bonnet with pins, damaged secondary lock but not needed with the pins $400
genuine c-west body kit rear bar and side skirts $1500
centre console with carbon material lid $200
glove box $100
gearstick surround and radio surround $400
guage cluster with 70xxx odd kms $600
full interior carpet in good nick just needs a clean $400
Floor mats $300
fuse box with all fuses $70
dash with side vents $200
radiator support ready for some repairs, pretty sure its the same as gtt $200
have pretty much all the seals, pm what you're after $50 each
genuine carbon rear diffuser, not sure what to price this at, throw me some offers, considering keeping it unless its worth something stupid.
all prices reasonably negotiable
pickup western Sydney 2146
<a href="http://tinypic.com?ref=noynp2" target="_blank"><img src="http://i60.tinypic.com/noynp2.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
  • Like 1
Thanks mate
Is the climate control unit the one that sits directly underneath the centre air con vents?
If you have a photo that would be great.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
