Testing Rb20 Coil. Car Suddenly Wouldnt Restart. Adding Lead To Coil To Connect Spark Plug
hi mates have a problem with my rb20 hilux that started this afternoon. I started it up and reversed out my driveway. car died when I put the clutch in to go from reverse to neutral (does this a lot when cold. usually restarts straight away. CAR HAS HALTECH E11v2 so prob cold start tune). today it didn't restart. cranked for ages trying to get it going but wouldn't go and battery got too flat.
I changed the spark plugs now so I know there good.
mainly what I want to know is how do I make a thing ive heard of before where you connect a spark plug lead to the coil pack then put spark plug into that like a common spark plug setup so I can look for spark to rule out spark issue. im not sure how to connect it onto the coil
thanks for now mates
I would say you have no fuel then either.
Do the usual, check fuses. Then i would pull cas out and turn by hand to see if the injectors click and I'd there is spark. Then you have to set the timing due to removing the cas.
What fuses should I look for? Since its an engine converted car the stuff is in different places and probably unmarked.
I get fuel pressure at the guage near the fuel rail so fuel pumps are going I believe. Dunno bout injectors.
Setting he timing is going to be shit I rekn. Apparently aftermarket ecus don't set the timing off the Induction loop thing? And I don't know what they have set it too. Or will it just be tdc in regards to setting cas timing?
Edited by joe blo
Like you said due to conversion what fuses do you check? If you don't k ow no way will I know.
The fact the pump is priming might mean the ecu Is turning on.
Fuel pumps wired to start with ignition is bad. Very bad in a crash. Should be controlled via the ecu.
Edited by Ben C34
Yea probs bad. I suspect that because they just run constantly once turn the key. Doesn't turn off when priming. Hopefully my ecu isn't dead. I don't believe the e11v2 has any lights on it so can't get quick idea if its getting power
I've done some more looking and thinking.
I hooked up spark plug to coil and prob have no spark.
Then removed spark plug and no fuel on it
I connected another cas I had (unconfirmed weather good or not tho) and turned it by hand with key in the on position. Nothing happened. No spark no injector noise.
My next thinking is I want to check power getting to the ecu and then follow from there. Problem is the haltech e11v2 doesn't have any lights in it to see if its powered up. Is there a way to check power to it?
It's a patch connector thing so the standard ecu plug is still there intact. I am now thinking of obtaining a standard rb20 ecu just to see if it lights up as my test for power getting to the ecu.
Any other ideas mates? Just bought house. Ment to be selling car. dream boats f**ked :(
did some more testing. didn't need standard ecu. I checked it with multimeter. has power.
what would be the next thing after the ecu I could check to make sure power is going out of the haltech ecu?
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
