Hi all,
I have a Jap import 2007 Skyline 250GT which I've owned for about 2 months. Its been through a Nissan service and check about a month ago and no issues identified. Drove perfectly till day before yesterday when it started emitting a beep, chime and a spoken message in Japanese every little while.
I recorded the message, and a Japanese friend told me it was a message from the GPS saying my destination was coming up on the left. This is so odd because I have never used the GPS (given it doesn't work here) or touched its settings. Anyway I managed to go in and turn "Guidance Voice" off which shut the Japanese lady up.
However I still have a beep every few seconds while I'm driving. There are no warning lights lit up on the dash, I've checked all the doors are locked, etc.
Any idea why the car is beeping please?
Cheers!
John
https://www.sau.com.au/forums/topic/448891-constant-beeping/
  • 1 month later...
Hi again maybe go on eBay and buy mechanical handbook which is available on dvd. On this disk is every a manual for every skyline from 2002 to 2009. Not expensive and will answer every future problem. Give it a go.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
