FOR SALE
VOLKRAYS SE37 (PAIR ONLY)
17X9.5 +18 5X114.3
$700
WESTERN SUBURBS
selling due to going 18s and more aggresive offset.
Im not interested in swaps and im not willing to ship either
wheels are available for pick up or may meet halfway depending how far.
contact me on 0421001058
post-89960-0-09073000-1411902190_thumb.jpgpost-89960-0-01466100-1411902200_thumb.jpgpost-89960-0-54687300-1411902218_thumb.jpg
Edited by ajay.R33
https://www.sau.com.au/forums/topic/449139-for-sale-volkrays-se37/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
