Hi all, I am having trouble with my S2 R33 GTST, have had a look around the forums but so far nothing has really helped.
The problem is when the car gets warm it just dies (can crank it over but wont fire) and wont start again until cold.
When the car is cold it starts first turn of the key and will drive around and wont miss a beat until its warm and then wont start again.. The problem has been occuring for a little while now but thought it was fixed after unplugging the ECU (Nistune) it didnt happen for about 150k's (the car doesn't get driven very often)
Have swapped the cas and afm (Z32) for known working units and it didn't make a difference, plugs look alright and the Splitfire coilpacks are only around 8 months old also unplugging the coolant temp sensor doesn't do a thing.. Car also drinks a fair amount of fuel round about 300 Kilometers to a tank on 98.
Could this be an issue with the tune? any help would be greatly appreciated cheers.
  • Like 1
https://www.sau.com.au/forums/topic/449301-r33-dies-when-hot/
Does it crank slow ? Like a flat battery ? Could be your starter motor solenoid sticking/faulty, a friend had an old hilux that would start fine when cold but once up to running temperature, if he turned it off he wouldn't be able to start it for a few hours till engine was cool again.
Hey guys sorry for the delayed reply..
Answers to previous comments..
defari- temp gauge says abit under half when it dies
blind_elk - Wont start if i give it any throttle just floods it and runs like shit when it eventually fires haha..
Lrs94- Nah doesn't crank like a flat battery cranks like normal
Kane_R32 - Fuel pressure is good after car shuts off
mlr- Where abouts are connections on chassis and block?
UPDATE- Turns out the cas i tried turned out to be an RB20DET one plug was the same but apparently the timing is different? And i ran the car the other day and when it got to temperature it didn't shut down and even took it around the block and let it sit at home idling and didn't die? :wacko:
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
