high flowed with bearings and seals 1200 the only reason i did it was coz my oil seals in my turbo went but yea i got a dual stage boost controller aswell r u sure its the cooler not the fuel pump thats not letteing ur boost go up coz its happened to a few friends of mine the pump goes.
Guest INASNT
nope fuel pump and injectors r running well! fuel pump cant effect how much boost u run, if the fuel pumps not running well then it will just run the engine lean!
its the cooler cause guy who got same power as me with same mods got a new FMIC put on and got his car dynoed right after me and he got 169kw@wheels at 9psi!!
in reality when u r running 12psi at intake the turbo will be running about 14psi atleast with the pressure drop being through the pissy small stock IC!
INASNT, where did you get your S-AFC tuned and how much? Have you thought about Water/methanol injection? Its half the cost of a FMIC, legal and unless you race around a track to get enough air flow through a big FMIC , works more efficiently on the street. Although a big FMIC does look cool!
Guest INASNT
Me and Grim were gonna put a water spray kit on the intercooler but in the end its not worth the stuffing around as the stock IC has such a small surface area where the air is cooled its pointless!
I got my s-afc tuned by the guys at ICE PERFORMANCE and it cost round $100.
I didn't mean a IC spray kit, but a true injection system via the intake plenum. No pinging, lower intake temp and more power at lower boost. For eg, A swisho system that Group A rally cars use only costs about $900 fitted against about $1600 for a DECENT fmic!. Less lag too over! as you don't have the big pressure drop of a huge cooler.
$100 sound good for a AFC tweak, will have to get down there!
Guest INASNT
oh ok, water spray for intake is a very good idea, and seem it work on cars running lots of boost, but no intercooler!
But u need sum sort of controller to control the system properly!
The 1'c i have seen incorporated it with an Autronic SMC ecu system.
Alcohol (isopropyl) injection is better than water(water is good though). The stock ic has plenty of pressure drop BTW, it has fairly poor flow. A modest sized front mount like the trust will increase air flow speed over the stock one (ie: less lag).
Look at it this way..
Summer is on the way.
AUS temps go pretty high in summer.
Just yesterday it was like 30 degrees and it's only going to get higher.
The standard cooler in winter is probably good to work efficiently at 12psi or less.
in summer, that standard cooler isn't going to do shit.
Get a good front mount and you will see an immediate improvement over the stock item.
If you have spent the money on getting a steel wheel on your turbo, then at the moment you won't be able to use that power until you change your standard pissy cooler.
You know the drill...
exhaust, filter, cooler, boost.
don't worry about water/metho injection or whatever...
do the basics first.
Keep an eye out on the forums for intercoolers that come up for sale.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
