Hi guys,
Ive recently bought a R33 and am having an issue with it. While in neutral, just standing still, the cars throttle hunts (if that makes sense). The revs rise and fall, sometimes a really small amount, sometimes rises to 1500 and then drops to pretty much 0 where it feels like the engines gonna turn off.
Car is a manual, completely stock as far as I know.
The mechanic said lots of R33's have this problem so thought id have a go to see what peoples opinions are.
https://www.sau.com.au/forums/topic/449862-idle-engine-hunting/
Clean out the iac. Search for a guide or whatever. Or ask your mechanic why he didn't just tell you the reason.
Will try to have a look.
The mechanic told me about it when I got it inspected, he said they will try to clean the throttle body and then see if they need to replace parts.
People on here usually seem to know exactly whats wrong so I thought id ask.
Don't clean the throttle body. That's not the problem.
Hopefully that's just lost in translation and your mechanic actually knosw what he is doing.
Didnt think it would be hence asking people who really know :)
This is what benC34 is referring to I think http://www.sau.com.au/forums/topic/110431-diy-aac-valve-cleaning-idle-reset/ easy diy job
I have bookmarked this page already, just waiting for a day when I have a bit of time to do it, tried to drive today with the Air-con on and the car stalled everytime I stopped cause the revs dropped...need to do this asap.
Definitely the iac! Scrap the mechanic and attempt to clean it yourself, a quick way to test this theory - spray some carby cleaner into one of the hoses attached to the iac and see if it temporarily fixes your issue.
Dont have a carby car so dont have carby cleaner....off to supercheap tomorrow.
Unless CRC degreaser works? Dont wanna try without knowing what it does..
It's really not hard 4 bolts, a hose and a plug then clean it and put it together, mine would always stall when I had the lights on but cleaning the valve fixed it
Yeah doesnt seem hard, just need time when I dont have uni,
I personally wouldn't recommend degreaser as it leaves an oily residue behind which needs to be washed off...
Yeah I thought so. Will wait for the proper stuff, till then just keep the revs up at the lights.
It's pretty embarrassing when your car just wants to die. Especially atva car meet
Happened to me while braking, I had the aircon and the radio on...didnt realise what happened till I noticed the HICAS light was on and realised the car had actually turned off...
Just quickly, is it possible to turn the screw so the car idles at like 1200 temporarily so that it doesn't stall? Until I get a chance to get the whole system fixed...or is that not good for the car?
Try it. It won't kill the car.
So I tried to turn the screw, there was no significant changes to the RPM, went from 900-1000, even though I unplugged one of the 2 plugs on the throttle body, but I drove with the Aircon and radio on and it didnt stop...so I guess it did make a difference...
This is exactly the problem that I was having with my 33. This issue points to the AAC valve. This is the valve that allows air into the motor when the throttle is closed, hence keeping the motor running. This normally has a carbon buildup and clogs the airways. That DIY link that was posted up is exactly what I used to take the aac off and give it a good cleaning. Problem solved.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
