R33 S2 Gts-T Engine Dies Randomly, Won't Start, Cas Replaced Issue Continues
Afternoon all,
Quick background:
- 1998 R33 S2 GTS-T with minor mods - brant security alarm fitted.
- 120,000 kms
Summary:
- Engine was losing power (would hesitate then pick up) at 1,500 - 2,000 RPM and then died suddenly after having been doing this for a few weeks.
- Electrical's continue to work and immobiliser not kicking in (engine light on), engine will turn over but not start immediately after.
- Starts again after 20 - 30 minutes and runs for maybe 5 minutes at most before dying again
- Fuel pump flowing ok and primes when power turned on, mechanic checked and fuel flow ok.
- Checked diagnostics and returned 11 CAS code (need to check again now it's died again)
- Replaced with second hand R34 NEO GTT CAS from JustJap, mechanic says car ran fine for "30 minutes"
- Picked it up and same issue occurred within 200m where engine died and wouldn't start.
Note:
- Coil packs / spark plugs were replaced approx. 10k ago
Looking to get some assistance in understanding what the issue may be and how best to isolate.
Consideration:
- AFM
- ECU
- Wiring issue
- Earthing issue
- Immobiliser
Links
Afternoon,
Idle prior to stalling was fine, no lumpiness or change in tone.
Quick update:
- have disconnected AFM to see if it would start in limp mode, engineer turns over but no starting.
- checked CAS is connected ok and rotated to see if any difference. No change.
- won't start at all now.
Next steps:
- purchase consult cable so we can see what the sensors are showing
- going to replace field filter and check fuel pressure to make sure issue isn't a blockage.
- will also look at testing CAS again and then start to check electricals and also lines to make sure no leaks etc
Update:
- Fuel Filter replaced, no issue with fuel as pushing out when pump priming
- ECU is now showing 55 (no error) and the engine still won't start.
- Next step is to check the wiring and see if there is anything other things broken
Does it just crank, and not even sound like its trying to fire?
I'll just throw these out there:
1) second hand CAS could be faulty
2) disable alarm if possible to eliminate 100% (seen faulty alarms still allow reds depending on set-up)
3) spark issue?
4) timing issue (could've jumped a tooth or stripped ribs on the belt? Worth having a look to see if the cams gears /belt spin while cranking.
Sorry to Hi-jack the post Links haha :whistling:
But I'm currently having the same sort of problem with my S2 33!
Car will die when it gets warm (bit under half temp on gauge) have tried two cas's and a different afm. When car dies it will crank but wont fire but if you leave the car to cool down it starts first turn and will run until it dies again..
seriously ditch the brant alarm.. biggest pos... they came factory in my sti... extremely annoying when they are on their way out.
i have the same prob... car is fine when cold.. when its hot it wont start... this is the alarm/immobiliser failing...
there has been some stories of the brant alarm immobilising the engine whilst freeway driving..
Edited by defari
Do you think this could be my problem also? I have a Mongoose M80
Edited by Brady_033
Afternoon all,
Thanks for the feedback.
Update:
- Have ordered ECUTalk to be able to look at what is being read from the sensors.
- Based on the ECU returning 55 (all is ok) I am planning to look at disabling or removing the Brant alarm so that we can rule that out.
Given the behavior and everything seems to be ok in general, i'll give the alarm the next focus and see where we go to from there.
The coolant temp sensor can do what your describing, i had to replace mine in my s2r33 as well... It showed an error on the pfc hand controller as well so consult should pick it up
Morning all,
Update in the last couple of days. Received consult cable hooked it up, ecu is showing 55 so no errors being reported.
Turned the car over and it started first go - left it to idle for a while and then have taken it up / down the road while monitoring. Everything was working ok which means I now need to consider heading out for a few longer drives.
Brant alarm keypad isn't lighting up so my thoughts are that there is still an issue and it's the alarm however i'll deal with it shortly.
Thanks everyone for your feedback. Still not confirmed what the root cause was however will see how it goes.
Links
  • 3 weeks later...
Morning all,
Thanks for the prompt as always good to close out a post.
  • After plugging in a consult cable and tracking the data when the car died the ignition was stopping. I called a Brant alarm technician to come and have a look.
  • Keypad immobiliser module had a faulty relay which was triggering when it over heated - this was causing the relay to trigger and cut the ignition.
  • Crank angle sensor was also replaced which has addressed the loss of power issue so all back on the road.
Links
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
