LOL, and I bet you cleaned her real good to..........
f**k I miss owning a bike :/
actually I was for a moment, hmmm if I let it eat away the paint it will look more authentic vintage hahaha
Okay got the fuel tank & fenders back today!
20150221_092711%201024x576_zpseggvnbdj.j
20150221_103059%201024x576_zpsmtmq10rr.j
I know my custom scheme might not be to everyone's taste, but I'm stoked with it. Such a cool little bike that turns heads. Plus I still have the factory kit to slap back on the bike for when I upgrade to a non lams bike
20150221_180322%201024x576_zps5kv0ead9.j
20150221_180210%201024x576_zpsq6xg8yqk.j
20150221_180233%201024x851_zpsr66uonks.j
20150221_180333%201024x577_zpsyd73wbyg.j
so what's next? Just enjoy it for what it is for the time being. I've got an aftermarket chip in it so I'll take it to a tuner to optimize my settings & voila!
Happy days!
  • Like 2
I've got some O'Neil body armour that you can have if you want, size medium. I'm near Liverpool.
It was great for hot days, more protection than leathers and covered by a long sleeve T it was 1 million times cooler.
  • Like 2
Sweet as! Can't turn down free armour!
I'm not from livo area but maybe I can pop down & pick it up on one of the public holidays coming up?
Otherwise I'm smashed for time between work, uni & the whinging missus ;);) (God I hope she doesn't spy on sau looking for my posts :P )
  • 3 months later...
Got a bit tired of the rabbit ears look. So installed some bar end mirrors & changed out the grips while I was at it.
From an aesthetic point of view I prefer it, but I personally wouldn't recommend it for this kind of bike, field of view is not as good & the mirrors shake like buggery (more-so than the stock mirrors :P)
20150627_152057%201024x801_zpsoq5iku4v.j
20150627_151956%20888x1024_zpsstd6o8mj.j
20150627_152032%201024x771_zpsxofvqzhi.j
20150627_152020%201024x715_zpsyiuuqbni.j
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
