Hi all,
Does anyone around Sydney (preferably Menai/Sutherland) have a genuine Bride recliner in their car that I could check out in the next day or two.
I'm looking at buying a set from someone but he wasnt 100% certain whether they are real or not. I have the seats at the moment so I can do a side by side comparison.
The 2 seats are a Gias Sport (looks 99% apart from a bit of a lean in the Bride writing - not sure if just movement from wear) and a Gias 2 Sport (suspect this one is fake due to stitch quality, foam and the tag).
I plan on going to Garage88 in the next day or two to compare with what they have, but figured it'd be good to ask people here first.
I'll post some pics when I get a chance.
Cheers
https://www.sau.com.au/forums/topic/451035-bride-seat-owners-around-syd/
The pics show:
Cushions side by side with Gias 2 (left) and Gias 1 (right)
Cushion on the Gias 2, kinda balloons when pushed down from the side. Like the backing has come free from the foam
Tag on the Gias 2
Tag on the Gias 1
The side of the adjuster for each has these very fine (almost invisible) holes with caps. Not sure if meant to be there or not considering its not the standard 3 'bolts' usually seen on fakes
Lastly is the sort of angle on the writing of Bride on the Gias 1 (the Gias 2 seems pretty level). Not sure if this is just movement from age and wear. Disregard the colour as its due to the camera
The pics show:
Top fake, bottom real. any serial numbers on each?
some of the fakes are almost indistinguisable to a genuine apart from build quality it should be solid ie if you try to bend the shoulder bolster on a fake you will hear a slight fiberglass cracking sound
So I took them to Garage 88 the other day and after one of the guys checked it out, everything seemed legitimate.
Comparing what I have to the Gias 2 Sport they have instore, the weight, flex (or lack of) and fabric quality all match up.
I've got an old just jap copy at home and the difference is obvious, but as you said Aggroman these days some are near perfect copies.
Outta curiousity what makes you say the top pic was fake?
Also got some serial numbers which seemed right G1 0608049244, G2 0709125658
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
