Hey everyone, I'm selling some gear off my GTR that is now running a singe turbo, E-flex and other gear, so all this stuff is of no use to me.
3" MINES front pipe, great condition, needs a clean - $700
F1806071-0172-4295-87FC-56E91E13E46F_zps
5EFA2E1B-E0EC-4127-8C87-5BBD4CADA629_zps
R33 Greddy dual gauge pillar holder - $150
9CB567E1-0076-4330-B50E-07BB5C169316_zps
Cool, old school, period correct Greddy 2bar boost gauge - $150
80305050-3D27-41AB-904E-388CFDE722B0_zps
R33 GTR door speaker covers, cut out of speakers - $50
EA2123FF-31BB-42A9-ADB6-C97DB2B317E7_zps
R33 GTR V-spec turbos, no shaft play that I can see. These were pulled off the car two months ago, I never owned the car when they were on, but they were making around 260hp at all four on stock boost I THINK***. I'll include stock manifolds and dumps if you want them, buyers welcome to purchase manifolds separately. $500
6BD29CA8-C5A3-4DC2-AAFF-DAFC425681D3_zps
2551E8BB-503F-4CE9-A1F1-21770EA52AFF_zps
R33 GTR MINES ECU (my car is an ex MINES car, lots of MINES goodies on it) - $250
4BD8E40F-37FE-44D7-89A5-609656909AE3_zps
R33 GTR intake pipe work (not including AFM's or intakes with pods in this) $200
606CF15B-F773-4E68-A6A4-2049F23A4E93_zps
MINES AFM's, similar resolution to Z32's, very nice condition, shiny MINES badges, rare - $300
FEAB54B5-8713-41EC-AA38-33506CEFEC04_zps
Pickup available in BRISBANE, shipping available at buyers expense.
Text me (Trent) on 0401029817
Luke, I can't get a quote off the top of my head for it, but the entire intake would be under 30 bucks easy if I boxed it up.
MINES AFM's sold.
MINES Front pipe sold.
Sorry for the late reply, Luke. I haven't checked the forum for a few days.
If anyone wants me, 0401029817 is the easiest place to get me.
  • 5 weeks later...
    • Omg Brake pedal removal.. FML!!
    • I mean, I can confirm the TPS is at 100%.... I can confirm when we installed the TB and setup the cable that the TB was indeed fully open at max pedal travel.. the same 'curve' (WRT MAP vs MAP) existed with the previous setup/TB/manifold as well... No, we did not do a run with no intake connected. I would love to go back in time to do such a run to rule out the intake. It would have also been good to do a run with the airbox lid off. There's a test there where increased IAT vs more available air could be a positive tradeoff. I remember taking the lid off my R34 Turbo setup back in the day and noticing a monster increase, even if IAT's did go up. Could be similar. Hard to test unless I find a very deserted road.
    • That's actually encouraging to be honest. my motor was rebuild many years ago but it's probably done less than 30,000kms and fucc all limiter or drift, majority street / drag / roll racing. It'll be fine 💪🏼 I don't even have lines or a can for the cam breathers installed yet, there is zero oil residue or splatter on or around them, it drives beautifully so it seems healthy. Just a ticky lifter, yet they're almost brand new oem genuine Nissan and haven't done many kms at all...
    • Have you confirmed the throttle body goes to WOT (and stays there) during the run?
    • I'm having a problem. I think it was mentioned above somewhere but can't see it.  I'm stuck in the cycle of, sand, filler, low spot again, put filler, sand, low spot again, now i put filler again and a thicker portion which seems to have helped but I got low spots in other areas. In the image. Circled in red thats where the original low spot was and the shape is the same as the red out line. I've more or less fixed that (still low spot up the top but now I have low spots where the green circled part is.  Is likely the issue that I didn't start with a course sand paper? I sanded the filler with 240 to reduce the risk of not going to far but maybe the issue is that I'm only taking off enough material to remove some of the filler but not the high spots. I now started sanding with 120 and I think I'm seeing a difference. I did fix one dent the other 2 are f**ked and seems like I made another low spot which is indicated by the furthest green circle on the left handside. Any thoughts and solutions?   Also second image. All of these rock chips, can they be filled in with primer or do i need to fill them all with filler/putty? So many rock chips on mine lol.
