Its labour... anything that requires labour is expensive. Fit the boost controller and intercooler yourself (if you want help im sure a few of us can get together and come over one day to do it) then take the SAFC to ed at integra for fitting. He then has a guy that will do a road tune of the SAFC for $150. The guy that does the road tune does extremely good jobs, and uses proper equipment like wideband O2 sensors for air/fuel mixtures, and has a laptop with lots of goodys hooked up to it so he can show you how the car is running, what its doing where, e.g when he did mine he showed me ignition was weak at this point, so to get around it, do this. :)
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
