The best way to check your plugs/coilpacks are actually doing something is to have a coilpack/s out, remove the CAS, turn the ignition on, ground the spark plug and then spin the CAS. FYI you have to spin it the right way so if nothing happens spin the other way. You can usually hear the injectors when you are spinning the right way anyway.
I may be mistaken, it might be the injectors that will only work in the right direction. Dont remember, but no biggie anyway.
Get a new ignitor, earth it and then try the above.
  • Like 1
I never said to disconnect no fuel lines :P
But if they are disconnected, then yes pull fuse
Haha.
I meant spray heaps of fuel around into the engine. Depending how much cas spinning fun you have ;)
  • 5 months later...
Hey guys so its been awhile since I updated my progress but I replaced the ignition module and got the car started but ended up 3 houses from the mechanics and it died again pushed it to the shop and after 2 weeks they told me the engine had seized and would never go again so I got a car trailer and towed it home so over the last few months I have pulled the motor out, striped it down (and found no signs of seizing e.g no marks on the crank) so proceeded to do a full standard rebuild so new bears for both crank and conrods, crank measured and polished, new piston rings, bored honed out, etc and the car now runs and has passed rego and I am now just faced with the fine tuning which is where my questions lay.
I am having trouble getting it to idle lower then 1000 rpm and my afm sounds like a vacuum cleaner it is sucking that much with or without the filter (which was only to see if the filter was dirty) I have read a few forums and done a few things from them such as cleaning the aac valve checked all vacuum lines by spraying carby cleaner on them but with no difference and at the moment my idle screw is all the way in and 1000 is the best I can get, it does idle hunt a little when coming to an intersection or stopping, I have the R33 s1 with the ecu that has the screw in the back but when I turn it there is no noticeable difference in idle except when It get to certain points which im guessing is some sort of marker where the idle increases until it gets off the marker and it never seems to stop turning like there is no end to the screw.
The first time I did it it was really hard to turn over by hand but was possible and I had done all the work with the engine in the car but this time the mechanics had already pulled the engine out and had already loosened the con rods so I didn't get to find out for myself just had to go on their word but this time its was a really good build and it turns over by hand heaps easier. I learnt alot from my mistakes the first time now I just need to fine tune it to get it running perfectly and every time it feels like I am getting closer to getting there I just feel like im missing something and can't quiet get it to idle properly.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
