For Sale
3.5inch stainless steel exhaust
With adjustable muffler
Goes from nice and quiet
To decently loud with a nice note!!
$350
Stock bnr32 clutch fan
Good condition, no cracks
$60
Bnr32 abs module and hardlines
Module slightly leaky
Removed abs completely from my car
$60
Pro sport strut brace for bnr32
$80
Arc bov and adapter pipe
$100
Stock bnr32 cam gears
$50
Stock bnr32 dump pipes
$50
Located western sydney
0425896150post-121965-14193040588066_thumb.jpgpost-121965-14193040746634_thumb.jpgpost-121965-14193040846558_thumb.jpgpost-121965-14193040978411_thumb.jpgpost-121965-14193041273127_thumb.jpgpost-121965-14193041389582_thumb.jpg
https://www.sau.com.au/forums/topic/452002-gtr-parts/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
