Hey guys,
I have no headlights, taillights, indicators, interior lights or dash lights. (battery light will come on when I switch the headlight switch - but will remain on until the battery is disconnected)
I do not have the two green ECU relays in currently..but have tested with friends and the same issue persists.
I have checked all under dash fuses...all good. Not sure about engine bay fuses though.
I have taken some photos of some plugs that I cannot find homes for..could you guys take a look at them and tell me what they are for?
THANKYOU FOR UNDERSTANDING I AM YOUNG AND THIS IS ALL PRETTY NEW TO ME HENCE I AM A CAR NOOB.
This splices out from the starter motor / alternator loom. Can't find anywhere to plug it into the alt?
These two plugs are coming out of the fuse box...no where for them to be plugged in?
These two plugs seem to be related to the headlights..but once again nothing to plug into?
These two plugs again seem to be near the headlights..any clue?
I believe one plug is for the power steering reservoir which has been cut on mine, but the other two don't seem to have a place?
Again, not sure what this plug does / where it goes.
This last plug looks important..but again no luck in finding where it goes. Help would be greatly greatly appreciated please :D
https://www.sau.com.au/forums/topic/452266-r32-engine-and-dash-wiring/
Fuark Maaate - good luck. Shoulda kept walking and kept your money.
Grab someone who has a 32 GTS-t and experience to help spend time sorting it. Park side by side
Who ever did that mess should of labelled when pulling plugs n cables etc...
Rusty as.
Good experience tho
Ps. Some plugs don't have a mate
Edited by Sinista32
The car was a rolling shell. I haven't touched any of the body loom..but I have put the engine loom and engine in myself.
Oh and as for the rust, that's the only place in the whole shell that has rust, so I'm not worried. Already got a plate to tack in there.
Green cable looks like the one connected to the ignition barrel. The one off it could be for the Ring that lights up the barrel ?
The one near the fuse box is that for consult ?
Edited by Sinista32
In Picture 1 and 2 you seem to be missing a resistor which attaches to the body.
Two of those plugs connect to it and a third which splices off it is not used.
Sort of like the Low impedance resistor for the injectors on the RB26
Edited by Sinista32
Cheers thanks man. I took two more pics.
First pic is another plug that I have no bloody clue what it is. I somehow missed it before. Any idea?
Second pic is where that resistor is supposed to go. Doesn't look like anything has ever been there on this car, although it could be mounted further back.
PS. Thanks for helping man, I really appreciate it.
Edited by Tenny
I made a quick video that might explain the problem a little bit better.
So basically, no ignition lights or power to anything else in the car. Windows, all lights, indicators.
Car will turn over when key is turned, but fuel pump is not priming and possibly no spark. Is it possible this is being caused by something that isn't earthed? I have tried looking for all earths and grounding them to the chassis / engine.
https://www.youtube.com/watch?v=vV3BmF8Auuo&feature=youtu.be
Cheers guys.
The silver resister box is the resistor for the air reg. Air reg will close from engine bay heat anyway.
The plugs under the steering column, where you're holding one wire, I'm guessing you've got a turbo timer loom there.
If so I'd chuck the turbo timer and associated plug-in-loom, then things will look much better.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
