Hey guys
Im about to buy this ecu and i need to know about the boost control with this unit. I know i cant just type in what boost i want to run on the ecu with the standard R33 gtst soleniod.
So if i get my hands on a avcr soleniod and use that in conjuction with the wolf3d software, that will give me complete boost control the same as any other EBC?
I dont want to spend a few hundred on a EBC if i dont have to if this method works. So just want to confirm if anyone has done this and it works ok?
Also i want to know if anyone has any base maps they could send me? I wanna have a go at installing it myself and if i could have a base tune to get me started that would be much appreciated.
My mods are
3" turbo back exhaust
Pod
FMIC
bosch 040
stock boost
Cheers
Matt
https://www.sau.com.au/forums/topic/45266-info-needed-on-wolf3d/
Guest darrinspencer
MJ I am in the small boat as you
I have the wolf computer but still have not fitted it yet
I pm Steve at SST a while ago the same question
his answer
"You can use the factory solinoid, but solder up the restrictor and redrill it to 0.5mm"
To us the factory solinoid I am pretty sure you need to unplug it from the factory harness and run new wires from the wolf computer?
Plug in the wolf and the boost solinoid will work with no extra wiring needed but if you want high boost you need to solder the factory restrictor and re drill smaller or fit a larger solinoid. Wolf car run any solinoid and works with inturnal and exturnal gates if you set it up right.AVCR solinoid is fine but save your coin and use the factory one with small restrictor.
yes i agree, the power FC is fairly restrictive with an automatic, especially because there is not many functions available for that type of tuning..
why dont you learn how to drive manual?... :jk:
the wolf has a wider range for the auto.. so good choice!
good luck with the tuning! :wassup:
Hi Abu, the standard engine ECU "talks" to the gearbox ECU and
(amongst other things) retards the ignition timing to smooth out the gearchanges. This also "unloads" the gearbox at the time of shifting, which lessens the torque shock on the auto. This extends its life considerably. The programming for this is quite complex as it has to account for gradients, as well as throttle position, gearchange point, engine rpm road speed etc. I suspect tha tthis is why Apexi don't make an auto PFC, they would have to charge a bomb to cover the cost of the programming t ocover the wide variety of power outputs. Noting that a standard ECU only has to account for standard power.
I have a Stagea almost here and it's an auto, good for towing the race car. So can you (or anyone else) tell me how well the Wolf handles the gearchanges in the auto?
I have recieved the maps, thanks for your help all :)
Sydneykid from what i have read from other people that have used this ecu in their auto skylines, they havent had a problem with the ecu except for the gearchange to be a little jerky. Maybe Steve can give a bit more of a insight on this?
I really like the software that comes with the unit, its really easy to understand and navigate. I cant wait to get this baby fired up now
Cheers
Matt
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
