Hire Car Insurance Cons
* Exorbitant costs - that appear cheap - for what you are covered for
* Exclusions in fine print seem to escape scrutiny whilst the desk salesperson 'sells' it to you
* Excess of up to $4,000
* Lack of hail cover
* Lack of cover from dusk till dawn
* Damage or loss caused to the vehicle due to even natural disaster where the repair cost exceeds DRF
* Damage to windscreen
* Damage to tyres
Domestic Travel Insurance Pros
* Cheaper by the week than most hire car companies rates for each day
* Greater coverage according to the PDS probably inclusive of the above Cons not covered by hire car insurance
Warnings have been put out by Choice and ACCC
eg. cases brought against Europcar and others
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
